Hi im having a little problem with my rear brakes light.
the right one has stopped working. at first i thought it was the bulb so i change the bulb.
but still it doesn't light up when i press the pedal. but it does light up when i put the headlamps on.
do you think its a rear brake switch problem? thanks.
by the way the left and middle bulb lights up when i press the pedal though.
it is easy to change by oneself or do i need a professional mechanic / electrician ?
thanks
kind regards
thanks
kind regards
