Radio Code Needed
Hi , I need a radio code for my K12 Details are BP234631992572 7642346318
I took the radio out today , mine is an03 plate and I can see the date 04 on the radio so a previous owner must have changed it .
If someone can conjure up a set of digits that would be appreciated ! Thanks ..
Hi
Thanks for your quick reply , The radio coder I have also threw 8771 and 0771 at me so in effect this radio is not accepting the code , is there only 1 set of digits for each radio or can they have several combination's ? methinks the radio could be faulty ? Thanks .
Tried my other Blaupunkt one and it gave same numbers - weird?!
Sure is ! When I gave the dealers my regi a while back they came up with something totally different so I kinda thought the radio had been changed , so its away from 1 prob to another . thanks .
Sorted
Thanks Guys , The digits were correct,(ta for these) info says to press < or > on channel button but its in the middle of this button that you hold down Thanks !
