Radiator Fluid & Coolant Loss
CMF_tiSh
Just found out lately that my radiator coolant gets drained everyday. I wonder why? the temperature is stable at 40%...
and the coolant container has no leak... radiator has no leak too.. where does my radiator water & coolant go?
does this mean the water goes to my engine? please need help....
CMF_tiSh
oki found it thanks. there is a leak in my upper radiator hose. needle sized hole... i ddnt see it first, but when i started to warm up the car the pressure boiled and revealed the leak.. thanks guys.. i was afraid it was a major problem...sealed it temporarily with devcon epoxy. but 2morow will replace the rubber hose....
