that will depend on what the regulator is set to porkAlso, Im gunna be running a 3 bar inline fuel pump. Will the existing lines be ok?
just check the pressure while the engine is,nt running neil, that will be the highest rate of return eh![]()
aye, and if it flows ok, then it,ll still flow ok when you are burning fuel ehLike, run the pump while engine is off ?
Loving your work as usual Pork, can't wait to see this up and running![]()
ExcellentHaha, I'm not gonna paint it, kinda like it like that too. Jus make all fittings straight and proper.
Do do you reckon the old mechanical fuel pump will be ok to supply the pot?
Or another low pressure electric?
Which hose is which? Can't see which hose goes where :s
Left is towards the rear seats
That's the fuel tank and fuel lever senderis that fuel pump?
That's what I've boughtiirc the metro turbo (which is a carb'd turbo) runs an out of tank inline 12v pump
You'd be able to keep rear seats I'm sure I've seen a "slim" pump somewhere
That should be enough then![]()
Using that pump on the swirl pot, but need a supply pump to the pot![]()
Should be fine as long as you don't smoke lol, couldn't you put it under the car (yes I know that sounds worse)
what i,m saying is your boost pressure will vary while daily driving mate, it might be ok on a track where you tend to be either wot or lift
