My Micra is on the verge of being crushed next week as well mate, sadly they seem to be a dying breed - I know mine is, everything seems to be either going wrong or breaking on it :down:. Plus I'm getting another car, and can't afford to insure 2, so one has to go
I guess I can start off with pros and cons of the K11, I'm sure other people will be adding to it.
K11
Pros
Cheap to buy
Cheap to insure
Cheap and easy to maintain
Cheap and easy to modify
Economical
It's Japanese, meaning it's almost bulletproof, to an extent
Cons
Prone to rust/corrosion, especially with older/higher mileage models - sills and arches are a particular problem area, and it can be expensive if it gets bad
MAF sensor seems to be a common thing to go wrong
2 star Euro NCAP rating - and it's actually safer for you to be a passenger in one than it is to be the driver if you have a crash
K12 (even though I've never owned one, I know people who have, so this is taken from their experience)
Pros
4 star Euro NCAP rating, and safer for pedesrians as well
Well built
Cheaper to insure in some cases than a K11
Can pick them up quite cheaply, even with low mileage
More spacious than a K11
Cons
Can't think of any off the top of my head :laugh:
As for what to look out for when buying a K12? Pretty much the same as any car - rust, corrosion, smoke when you start up or rev the engine, etc. And as Pepper says, £2000 will buy you a fairly decent low mileage K12. Just keep an eye out on Auto Trader :grinning:.
As I said, I'm sure you'll get a lot of people adding to this (Y)
