I should / could find this out myself, but is the driver side engine mount the same on a cg10 / cg13 ??
nice offer rich, could you please get me a pic of the mount first, i want a couple of good pics to see the quality etc of it. then ill decide. where are you btw?
just to get it running im going to carb my conversion using the standard k10 carb setup eventually leading onto a bike carb conversion or similar. hopefully it will be a flyer
Portsmouth area.
I am not going to show a picture of the mount because the information in the picture cost me a fortune to find out.
Kristian did the engine mount, he drove down from Manchester area and spent a day doing it. It has been done to a high standard.
Yes po88da
Matt if you wanted to give me a hand getting the car running, I would be happy to let you have the car for less than I would do otherwise. Worth considering?
All it needs to run is a fuel pump, and a live feed to the ecu wiring. The throttle cable is marginally too short / change for k11. Would only take a few afternoons max. I have k11 front disk to go on too.
