T templar2k5 Mar 16, 2012 #1 Hi everyone, my Mum's Micra ('98 1.3 16v) has developed a fault where the handbrake light on the dashboard, will sometimes come on when the handbrake is down. Is there a way of checking the sensor? Many thanks : )
OP OP T templar2k5 Mar 16, 2012 #3 frank said: its usually a sign that the brake fluid needs topping up Click to expand... Cheers for the quick reply, frank. Is there normally a certain type of fluid that the Micras tend to prefer?
OP OP T templar2k5 Mar 18, 2012 #5 Right, I've had a look at the brake fluid, and it's topped all the way up! What else could be causing this problem, then? Cheers people ; )
karlj Mar 18, 2012 #6 Have you replaced the brakes recently? If not might be worth doing so, or you could just try bleeding the brakes
frank Club Member Mar 18, 2012 #7 templar2k5 said: Right, I've had a look at the brake fluid, and it's topped all the way up! What else could be causing this problem, then? Cheers people ; ) Click to expand... mine looked full too, but when i added some fluid the light went out
OP OP T templar2k5 Mar 18, 2012 #8 frank said: mine looked full too, but when i added some fluid the light went out Click to expand... The fluid was over the "plunger" in the container. Is this how yours was, before you put the fluid in?
