Power Inverters
Hia Guys,
I would like to get a power inverter for my car so that i can change my laptop 'on the go'.
Now, here is my question:
When i tried to get the Wattage needed i looked at the charger input which was 240V at 1.5 amps. and Volts X Amps = watts right? so i would need a 360 watt converter!? that a third of a kilowatt!
am i making a mistake here?
i think a DC-DC converter would be a better option ed (maplin do one, £25 ? but they wont be the cheapest eh)
Yes in rough terms thats right volts x amps = watts.
however i would have thought as most laptop psu's are dual voltage, ie 110v and 230, the 1.5A would be for the 110v, and it will be no where near the 1.5 on 230V
laptop psu.s are about 100watt output so would be a similar input, assming losses say 120watt input, @ 230v ~0.5A, at 110v ~1A.
you can get some real cheap inverters nowdays, check to see if maplin has anything on offer.
non true sinewave inverters are more risky than dc-dc gear ed :eek: (ac multivolt adapters are dodgy like you say tho)
anything that increases voltage involves chopping the original 12v up and making it noisy etc, i have one of those 12 to ~19v things, used it loads never had any trouble, and at ~£15 its fine, but if i were going to fit someething semi-fixed in the car id have a small <300watt inverter, that way you can as noddie says charge a phone etc, keeps your options open.
the laptop psu you have converts the ac going in straight to dc anyway, so in theory you could supply them with dc if it were above 100v, so the input doesnt have to be highly accurate anyway.
I have loads of 12-240v mains inverters, and never have a prob, I use them for all sorts. Get a 300w one minimum to be on the safe side, Modified sine wave will be fine, then you can do with it what you wish. DO NOT use the 12v dash plug as it will not be able to cope with the current of a laptop continuously. Wire it directly to the battery with at least 30A cable.
