I'm sure most of you know I have a problem with misfiring and 'stumbling' at the moment. Cylinder 3 seems to flag most so I've just stripped it all and swapped coil packs 1 and 2 and coil packs 3 and 4 to see if the fault code changes from P303 to P304.
I'm now thinking it may be injector related. With the manifold off, you can look into each inlet port at the 2 inlet valves. On cylinders 1, 2 and 4, the inlet ports are immaculate. Port 3 has a weird blackish residue and some cream coloured residue all over the aluminium walls.
Could this be injector related? If it was a coil pack/ignition fault the visible evidence would be in the cylinder or exhaust manifold surely fwn.
