Hi guys
Missus has a 97 1.0 Micra with no extras
Been fixing her up and only couple bits left
The wipers are weird, the "zero sensor" seems broken... I'm making that up of course
Normal and fast wipe works fine, but when switched off will stop wherever it is
Intermittent goes up 3/4 then stops
The single mode (push up) wipes fine but stops mid screen
The only way to zero at bottom is to hold the single mode on(up) and release at bottom
Assuming this is a sensor, chip, or mechanical switch... But where do I find it?
