Polyurethane Bush for front control arm SIZE
Hi guys, on strongflex website, of the micra k11 front Wishbone Bush there are two sizes, 28.5mm and 26mm.
Is there a way of knowing which one it is, without going there and measure?
Car is a micra k11 from 99, facelift gx
Thanks guys
Enviado do meu MI 8 através do Tapatalk
Damn it.. Didn't help
On the pictures of strongflex website none of them has that metal casing
I run the 28.5 (remembed right) yellow bushes that are abit stiffer then the red
Alot stiffer then stock and lot less flex the stock so no/less positive camber on the outer wheel,
Get a pair of micrometers and measure the inner dia of the wishbone hole for the bush,
Believe the 26.5 is for if you keep the orignal metal bush on the wishbone
The Polly done have or need the outer metal
Sent from my moto g(6) using Micra Sports Club mobile app
So could I just buy the 28.5mm and don't use the metal casing that the original bush has?
Yes
Just double check the sizes first,
I got the bush out then carefully cut the sleave
I perfer to use orignal wishbones and just strip and refurb them along with new ball joint of possible , not a fan cheaper repo ones had one drop the ball joint and seen plenty break and such
