any scratches / damage?
Hi frank,i saw that coming
there are a few threads concerning changing the cross member mate, you will have to drill and chisel yours off, and you will need the n/s headlamp panel and slam panel anyway (so buy the ebay one)
Thanks frank,all the crossmembers are the same mate, but i doubt if you will get that n/s headlight to line up without changing the panel personally
Hi Frank,all the crossmembers are the same mate, but i doubt if you will get that n/s headlight to line up without changing the panel personally
Very many thanks frank,the caliper will be ok if the piston still moves ok hakim, and you just remove all the bolts and the support bar will drop down, and best fill with fresh fluid mate
Thanks frank,the caliper will be ok if the piston still moves ok hakim, and you just remove all the bolts and the support bar will drop down, and best fill with fresh fluid mate
Very many thanks Frank,there is 1 long bolt through the mount and rod, and 2 bolts into the floor at the back eh
the preface 1.0 one is a different shape, and once the brakes are fitted and set, dab some sealer onto that little tear
Thank a bunch frank,if you force the member bolts too much the captive nut can shear off hakim ! and you have to cut a flap in the floorpan to access it.
its probably cross threaded, so you may need to run a tap through the thread (bear in mind some k11 chassis bolts are metric fine)
and ring spanners and 6 point sockets butcher the bolts less than open ended
acquire a tap and clean the thread mateThanks frank,
How do I do that?
Regards
Thanks a bunch frank,acquire a tap and clean the thread mate
http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313.TR0.TRC0&_nkw=metric fine tap 10mm&_sacat=0&_from=R40
Thanks karlj for the advice,Hazara your best to buy you own tools you never know when you'll need them, but remember you get what you pay for so buy the best you can
Hi Frank,reusable mate (if you dont break it )
Thanks frankdoes,nt look too bad eh hakim and try blowing down the pipe eh
Very many thanks frank,you would get better gaps i suppose mate, it depends how fussy you are
Very many thanks frank,there are various metric fine,s mate, you will need to measure your bolt really, so if you count 10 threads within 10mm, then the pitch is 1mm.
and a plug tap is only needed for tapping a blind hole (a hole that has a bottom )
Very many thanks,they have a square end hakim, a pair of molegrips would suffice
Hi Frank,tiz mate and we never stop learning eh
Very many thanks Frank,you could slit it with a hacksaw hakim, (to weaken it) then shove a bar up the chassis and bash it straight
thats the idea mate then weld it afterWill it not weaken the chassis?
Regards
Thanks a bunch frank,thats the idea mate then weld it after
Thanks a bunch frank,you will need to slit near the top mate, on the sharp fold/kink about 3" deep i guess
Hi Frank,yes and yes
Very many thanks frank,lookin good hakim finger nails are far too clean tho
no they should fail it without welds (depends how well you cover it tho)
that,s a dual pump aint it (forwards for front screen, backwards for rear ?)
and 2 pack glue and/or self tappers
Thanks frank,its more accurate to measure 10 threads mate (then divide by 10 obviously) and you should weld that cut tbh, and also weld where the spotwelds were
