Thanks a very mGive us a picture?
Sent from my GT-I9100 using Forum Runner
rear wheel ??
Very many thanks frank,panhard rod eh, and yes the backend will be a bit "jelly like" but ok to drive with care
Thanks frank,its hard to tell which part has broken now you have roped it together mate, but i guess the bracket has broken from the axle ?
a garage may insist on an axle change tbh
that axle looks very rotten mate !
best to replace tbh, but they are usually a hell of a mission to remove the bolts tho
Thanks.I had the same a while ago, I got a new axle but I also welded it back on but weld a plate over the rusted area then weld it, better to get a new axle as mine only lasted a month then broke off again
Thanks,I got one for 40 pounds with all the arms
Hi, Frank,best to replace tbh, but they are usually a hell of a mission to remove the bolts tho
that will probably depend on the spec hazara, and bear in mind that some of the ABS models had drum brakes ehHi, Frank,
A quick question:
Does the GX 1.3 98 have ABS?
Regards
Very many thanks frank,that will probably depend on the spec hazara, and bear in mind that some of the ABS models had drum brakes eh
you will see a caliper if its disc braked mate.
and a rotted axle often write,s the car off tbh, here,s an x reg drum brake one from my local yard (scrapped because of the axle)
polly do you have one or two cars?how bout SORN the car off the road to reduce running cost to a min and wait until you have enough saved to replace the axle?
an ABS axle will appear have a black cable trailing from both ends of the axle into the middle and up above the fuel tank.
Mate bite the bullet and change the axle. I wouldn't let mt mrs off the drive in a car like that. If it has to be done, it has to be done.Very many thanks for everyone's participation and suggestions.
It seems I have to either replace the Axle or break the car. Breaking the car is out question while replacing the axle will cost me and at the moment I really can not afford it straight away.
However, to finance the repair, I have to break my other car which is a cat. c and in front of the house.
Since I don't know nothing about breaking, posting and pricing the parts and even the name of useful parts to be sold.
I would be gratefully and really looking forward to your advise, suggestions and help in one or the other. Please help.
Now, apart from a buy & Sell account what else do I need to break my car and sell ?
How/where to find the cheapest and reliable courier service?
How to go about with breaking the car?
Please help and advise, your help and advise is grately appreciated.
Regards
Thank for the advice aplina,If ypu post up some pictures of you car that your looking to break, i.e. interior, seats, dashboard, electric windows, engine bay etc, exterior, wheels, spoiler, bumpers then people on this forum will have an idea of what you have that you want to break to sell parts, and hopefully someon on this forum can help if they need anything for there car and this way hopefully you will get your other nissan back on the road properly!!! so post pictures Hazara!!!! thats the first port of call!
J
Hi Paul,
Very many thanks Paul.not easily without some effort cos the non-abs axle won't have the hole & mounting feature for the sensor.
anything is technically possible but is a question of effort, money, resources, knowledge, time, quality, reliability etc etc
converting non-abs to abs axle won't be easy without compromising all of the factors listed above cos the non-abs axle won't have the hole & mounting feature for the sensor.
Hi Frank,best to replace tbh, but they are usually a hell of a mission to remove the bolts tho
heh, bolikin from your daughter eh the chassis legs look fine eh, just the bottom of the o/s one looks over a bit (big hammer job once the cross member is off)
i saw that comingThe next couple of questions:
Thanks Frank,i saw that coming
there are a few threads concerning changing the cross member mate, you will have to drill and chisel yours off, and you will need the n/s headlamp panel and slam panel anyway (so buy the ebay one)
