Trung
Founding Member
A pair of LED bulb for tail/stop lights.
Each bulb houses 35 bright LEDs as well as being brigher than normal halogen bulbs, it provides instant lighting response.
The rear and the side of housing also has LEDs so it can emit lighting off the reflective casing in your rear cluster.
*These are perfect for those with clear clusters because it emits red light. You don't need to use painted bulbs anymore.*
It'll be £15 posted for the pair.
I also have a set of brand new PIAA Xtreme White tail/stop bulbs.
It's rated at 27/8Watt so it's brighter than the standard 21/5Watt bulb currently in your car. (Unsuitable with clear clusters)
£10 posted.
RRP £15 at any PIAA dealer.
£10 posted.
