Info Parts Reference
Nissan March FHK11Cabriolet Roof Cover Assembly (vinyl roof with rear heated window glass)
For the complete roof cover there are 2 Nissan part numbers:
97150 77B02 = £2,327.30 + Freight!
97150 77B03 = N/A
Andy :D
Nissan March FHK11 Cabriolet Emblems and Label
These are the Nissan part numbers for the Chrome Emblems (Front Bonnet and Rear Boot Lid) and the Rear Boot Lid Transfer Label:
A: 62890-72B00 = £19.27
B: 84890-77B00 = £19.27
C: 84895-77B00 = £10.01
Andy :D
Replacement Brake Parts and Part Numbers
* It is important to give full details of your vehicle details including: year, model, vin/chassis number, engine number and if it has ABS!
Front Ventilated Disc Brakes:
Brake Pads:
Brand: Blue Print
Part Ref: ADN1422103AF (D1215MO1)
Ventilated Disc:
Brand: Blue Print
Part Ref: ADN14393
Caliper Seal Kit:
Brand: Budweg
Part Ref: BCK 4862 (28553DT)
Rear Drum Brakes:
Shoes:
Brand: Blue Print
Part Ref: ADN14147 (K1204-01)
Drums:
Brand: TRW
Part Ref: DB4 226
Brake Cylinder:
Brand: Blue Print
Part Ref: ADN144R
Replacement (Up-Grade) Brake Hoses (Front and Rear):
High Quality Stainless Steel Braided Hose and Fittings:
Nissan Micra 1997 1.3 ABS (rear drum) will fit!
Brand: HoseTechnik
Part Ref: SBH-NIS-4-042
Hope the above helps!
Andy :)
I didn't get any matches using the reference numbers for pads. I'm pretty sure the right ones look like crabs with their adjustable spanner type claws up. Does that ring any bells Andy? As Frank suggested, these are a carry over from the K10.
I read the thread Frank, and it gives the impression that replacement pads for 1997 Micra Cabriolet with 238mm vented discs are not available in the UK. Is this true, have none of the cab owners replaced their front pads? My discs are fine and calipers could probably benefit from the kit, but pads are kind of essential. Caliper is marked 18V. Please can someone pinpoint the ones I need.
These come up for Nissan March 1997 1.3 Petrol at Euro Car Parts. Are they not correct?
http://www.eurocarparts.com/ecp/c/N...63e0a111048c9d76179e8acb4e9dac22b3e3ff&000036
They also supply Pagid pads which look closer to the correct ones. I think these Blueprint are correct:
http://www.ebay.co.uk/itm/NEW-OE-QUALITY-BLUE-PRINT-FRONT-BRAKE-PADS-SET-ADN142103-/311656997731
Re: Brake Cylinder - 'I have also checked with Blue print and they do not have a stock number ADN144R on their database, we are very sorry about that!'
Going to try taking measurements from existing cylinder. Anyone had any success finding correct replacement cylinder in UK?
Hi mate I replaced my rear brake cylinders and shoes with blue print ones?? :-S I will re-check the part numbers I am sure I kept the parts boxes! B-)
Finally a Ta Daa definitive list of pads for the standard Sumitomo calipers used on the March Cab. These are Nissan Sunny N14 or Nissan 100NX pads which have been confirmed by Nissan as fitting our front calipers. Thanks to Jason Quigley for his parallel research, confirming mine.
This item is equivalent to the following OEM numbers: MINTEX: 21657, MINTEX: 21658, MINTEX: 21659, MINTEX: 7359D510, MINTEX: 7389D510, NISSAN: 4106050Y94, NISSAN: 4106062C90, NISSAN: 4106063C90, A.B.S.: 36728, AKEBONO: AN327WK, APEC braking: PAD752, APEC braking: PAD782, ATE: 13046059412, ATE: 605941, AUGROS: 55577092, BARUM: BA2113, BENDIX: 572210B, BENDIX-AU: DB1210, BLUE PRINT: ADN14237, BLUE PRINT: ADN14299, BOSCH: 0986460997, BOSCH: BP563, BREMBO: P56027, DELPHI: LP783, DELPHI: LP804, FERODO: FDB763, FTE: BL1366A2, HELLA PAGID: 355016351, HELLA PAGID: 8DB355016351, HERTH+BUSS JAKOPARTS: J3601048, INTIMA: MD1133M, JAPANPARTS: PA149AF, JURID: 572210J, MAGNETI MARELLI: 363700203004, MAGNETI MARELLI: T3004MM, MGA: 341, NIPPARTS: J3601048, NISSHINBO: PF2226, NISSHINBO: PF2375, NISSHINBO: PF2410, NK: 222236, OPTIMAL: 9725, OPTIMAL: 9814, PAGID: T3004, QUINTON HAZELL: 2761, QUINTON HAZELL: BP603, REMSA: 036402, ROADHOUSE: 236402, STOP: 572210S, TEXTAR: 2165701, TEXTAR: TX0034, TRW: GDB1012, TRW: GDB1170, VALEO: 551774, VALEO: 598628, WAGNER: WBP21657A
Brake Pads:
Brand: Blue Print
Ventilated Disc:
Brand: Blue Print
Part Ref: ADN14393
Caliper Seal Kit:
Brand: Budweg
Rear Drum Brakes:
Shoes:
Brand: Blue Print
Drums:
Brand: TRW
Part Ref: DB4 226
Brake Cylinder:
Brand: Blue Print
Part Ref: ADN144R
Brand: HoseTechnik
Andy :)
Why blueprint?? They're such a basic brake pad
Mintex part numbers are wrong.
Mintex: MDB1720
They're for a K10 Micra
Did someone order parts from this site before? i found that they have an extensive list and they are getting dispatched from japan.
i want to order ca cover for the roof when it's down. if some has experience with this help would be much needed and appreciated.
also...the part numbers in the previous picture don't seem to match up in this site
Longest auxiliary belt for alternator and air conditioning.
I have just had this belt replaced and it is none of the options listed for the K11 with similar combination of equipment. My mechanic finally got the right one at belt number 8. The one you need is 6PK955 ie. 6 ribs and 955mm long. He couldn't get that one so I have the next shortest which is I think 949, accommodated by the adjuster.
CV Joints!
After buying some standard joints for a 1.3 K11 with ABS and finding they don't fit because there are only 19 splines on the car drive shaft and 22 splines in the 1.3 Joint (though everything else is the same) I can now confirm standard K11 1.0 with ABS CV joints fit perfectly though getting hold of them isn't as easy as it should be. One major factor told me 1.0 K11s never had ABS, another ordered the listed parts but they arrived with no ABS ring and a place I tried to order them from on line said they wouldn't supply because my reg no said it was a 1.3. In the end Harrods in Marple got me some ODM CPSDN1120AK /DN11220AK joints within 24Hrs. Never heard of ODM but couldn't find anything too bad about them on line. They fit perfectly.
