The one that says 2 coats of primer, 3 coats of base, 3 laquer or summin and times, i just put first coat of primer on, leaving it 15 mins then another coat but then im lost XD
what is it your painting.............
anyway rub down with 800 grit wet and dry.............apply a dust coat of primer allow to cure for 10 mins then apply heavier coat of primer allow to dry and scuff over with 800 or 1200 wet and dry blow off dust particals and tac rag off finishing with panel wipe to remove grease and finger marks........Then apply dust coat of colour allowing to cure for 10 or 15 mins then apply heavier coat if good coverage has been had allow to cure completly and scuff off with 1200 finally apply 2 or 3 coats of lacquer..........if you want a glass like finish when dry rub over with 1500 wet and dry with warm soapy water
