Nissan Micra k12 1.2 Petrol 2007 eml light on code P0132 O2 sensor Circuit high voltage bank 1 sensor 1 rough idle hesitation upon Acceleration reset Eml few miles later Eml back on with same symptoms,Changed front O2 sensor but Eml and symptoms back again after only a few miles,should I replace the back post cat sensor aswel or any suggestions scanner showing both sensors voltage stable at 1.275 volts with eml on please help
