Ceirwan
Well the car isn't proving as reliable this time round!
A current issue is when I'm driving around town in stop start conditions the temperature of the engine slowly rises until its pretty much brushing the H mark, the fan doesn't come on and I have to use the manual switch that has been installed.
However even with the fan on the temperature doesn't seem to come down, I had to park up for five minutes on the way home today because it was getting that hot.
Its never going to cope in summer!
As well as the issue with the fan not coming on the cooling system seems to have lost a lot of efficiency, even in stationary traffic it never used to go more than 3/4 of the way up the gauge.
I've looked at the coolant but am unsure of what level it should be without an expansion tank?
When I turn the fan on manually, the air coming off the radiator is cold rather than hot as I'd expect.
Is this likely to be thermostat, or dunked up radiator??
Rich
Rich
