Unlucky 7
Air - check:
1. air filter blocked
2. air intake blocked
Fuel - check:
1. fuel pump is running when the engine is running
2. fuel filter is not blocked
Spark - check:
1. there is HT getting to the distributor
2. is there an aftermarket alarm on the car stopping the ignition
Exhaust - check:
1. catalyst blocked (check both stages)
Qs for you:
What happens at the end of the 7 seconds - does the engine cut out immediately or does it falter and die gradually ?
Do you get any abnormal warning lights displayed when the engine stops?
How long do you need to leave it before re-starting to run another 7 secs ?
Can you rev the engine during the 7 secs - if so, does that shorten the time the engine runs ?
What happened between when the car was running OK and this situation ?
