Just a small one but annoying me because I like things clean. Is it possible to remove the sump just using stands? If so, should I replace the sump or just clean it up and use a sealant of some sort?
If the metals wearing or rusting through at any point I'd replace it. You need a sealant that can withstand oil contact to refit it - something like Loctite 5910 .
it may be the oil pressure switch that screws in near the oil filter these are known to leak a bit throught their threads
ptfe tape on the thread should stop it
I'm actually a bit worried about mine tbh, there's a rust patch about 3"x3" that feels quite deep. Might submit a request to one of those online scrappies that sends the request to all the big scrappies...
