V Vince Mar 28, 2011 #1 Could someone help with the oil levels on the K11 stick, where exactly should the level show.
hoodedreeper Ex. Club Member Mar 28, 2011 #2 At the end of the stick,the actual stick should 'kink' down. The oil needs to be in that kink,if that makes sense?!
pollyp Club Member Mar 28, 2011 #3 only check when engine's cold and hasn't been running for the past few hrs and car is on flat ground
davey1991 If its not scrubbing, its not low enough. Mar 28, 2011 #4 You always check when the cars warm, always.
S silento Ex. Club Member Mar 28, 2011 #5 you can check when its warm. just give it at least 10 minutes after a drive to allow the oil to sink back to the sump.
