frank if it does consume a lot of oil and blue smoke on start up this means its knackered? how do you fix this? new engine
if you do drive it hard then id be sure it is the rings :wasntme:not sure when ragging it
there would be no need for anyone to follow you because there wont be such a large amount of smoke that it would be noticeable from the car behind... if there is then good luck to your engine
burning a bit of oil around start up and is not uncommon or very much harm for the car... i find much cheaper than a new engine or a rebuild is just keep topping it up with oil
