oil filter change
Hi, is there a way to remove and replace the oil filter on a 2001 k11 1350cc. It's bearly visible never mind getting a grip on it. (Poor location for a service part)
Is there a way to do this without a jack and axel stands and getting properly underneath the car.
You should be able to reach over and undo it from above.
Might have to remove the airbox for a bit more breathing space.
Thanks, ill have another good look in the morning. Ive just done the plugs, fuel and air filter and decided against doing any more this evening as it looks like rain.
If you haven't done this already - I have just replaced mine. Wasn't the easiest to get too, and you will have a task taking it off. Will be easier if the car is on some sort of ramp.
