OBD Scanner for 2001 K11
First I will tell you the car specs,
Year - 2001
Engine - CG10
Ok guys, I know this might be discussed everywhere. But I'm really confused about this OBD scanner. I tried many cheap ELM327 versions as well as this VAG-COM VCDS Scanner Tool OBD2 KKL CH340 409.1. Neither of these works for me. Can you please help to find a good ELM327 reader for me. I don't need a very expensive one. Need to read RPM, O2 Sensor and some I/M reads would be enough. I'm just exhausted by trying most of these adaptors. I tried these,
This is the one I have. Its Non Pre coil pack version. I found out in 2005 Nissan Navara has the same OBD version and they have posted something with 14 pin connector change to OBD and using that. Need to try that. Thanks Maarten.
