Not starting please help.
Hello every body,
Today wanted to start the car to change break fluid and oil but the car does not start. Can someone help please?
The car has been there for last year and half. Last time started it worked was over a year ago. When turning the ignition it goes ghooop. And do nothing.
Will it work if I push start? Or do I have look for rust somewhere deep inside?
Update on replacing axle. The axle is replaced. Panhard Rod to be fitted and stabiliser which needs to re threaded the nut on axle.
Regards
remove fuel pump fuse try starting a few times. then do the same with fuse back in.repeat couple times.
Thank r-reg-sr and andy,
The ignition is not turning properly.
The battery shows -11.89!!! Connected the spare battery as well.
Regards
Should t battery be reading 14v. Doesnt that mean you have a dodgy altenator?
Thanks andy,
I had two barriers connected both and did not work. Placed one to be charged for 18 brs and today connected and the car started.
Today did the bleeding as well and will do coolant and oil in the week if the weather permits.
Regards
