S
Sacal
I have a problem with an R reg K11 which wont start, I have looked and searched but dont seem to be able to find a solution, so thanks in advance if anyone can help!
The car has always run very well, starting first time etc. Last night I parked the car as usual, this morning it would only turn over but not fire at all. It sounds like it is going to fire but then just continues to crank. All the simple stuff was checked first, battery, fuel, plugs etc but no fault can be found. Tried a jump start with another car but still the same problem, just cranks without firing, I went out and bought a gunson fault code reader, but this shows no fault in the system anywhere!
any ideas? im starting to think its the imobiliser.......thought of fuel problem also but i guess the fault code reader would have picked up on that.
if any more info is needed, just post it up and i'll keep checking back on this post.
Great site here
Great site here
