Hi all, just upgraded the stereo in my k11, chopped of factory wiring connectors
and wired direct all work perfect great sound factory front speakers and Vibe 6x9s rear.
Now the but! dont seem to have any speedo lights ?
If you only cut those two Nissan radio connectors this shouldn't happen. I would remove radio and drive around without it as long this issue isn't resolved but that is just me. If you accidentally touched some wires that already have been custom that is something worth checking. Also it is a lot easier fault searching without that radio and double check all connectors original or not for misconnection. Don't start fixing things before you have found the cause, this might make things harder to fix.
