I hope this a comprehensive an answer for all questions that have been asked
The car was resprayed a year ago and the bodykit was repaired and the whole car was resprayed. The car at the moment is a rolling shell which still has fitted a gti-r cross drilled brakes and uprated suspension, which comprises of eibach springs with bilstein dampers on the rear and 3 month old koni's on the front. The fronts were fitted 100 miles before the car died, this was done as the bilsteins were way to stiff for the road and the koni's are more forgiving, also the bilsteins died. The brakes i fitted over the summer at a cost of £200+ and comprise of uprated cross drilled discs with motorfactor pads, i have never ever managed to over heat these brakes.
The interior has a full dash, carpet, roof lining and all bits that should be there, however it is missing it's seats (front and rear) and door cards. I do have in my garage a full SR interior that i can fit for a addition cost to the buyer if they so desire.
The loom is complete however it is recommend that the internal part of the loom is replaced as i think it was what caused my ecu to die.
Currently there is a dead engine in the engine bay, but this will be removed as it is not worth getting it working again (needs cams, rocker cover and quite a few other bits).
To get the car working and back on the road you will need
1- A engine
2- engine bits (tb, battery, etc) i can offer a alternator, dizzy
3- A full exhaust system, i can only offer a decat
4- ecu
5- interior, again i can supply if wanted
6- alloys, optional as its on steelies
7- gearbox
Basically a donor car that is rusty is needed
