Normally you put the nozzle between the air mass sensor and the throttlebody but the first K11 have the air mass sensor inside the throttlebody. Where to go with the Nozzle. It is a wet system.
possibly tap it in just underneath the throttle body... where there is a vaccum fitting already screwed in. not the ideal position, but about the only one with the standard plenum/afm/tb. unless you change to a different air flow meter.
