Boobtube Jan 10, 2022 #2 You will need a convertor that plugs into the antenna socket (and needs 12 volts) to convert American FM frequencies to the frequencies this radio is set for. It's a small device and inexpensive. https://www.amazon.com/Expander-Converter-Shifter-Japanese-108Mhz/dp/B06Y2Z93MW
OP OP stephon Jan 15, 2022 #3 Boobtube said: You will need a convertor that plugs into the antenna socket (and needs 12 volts) to convert American FM frequencies to the frequencies this radio is set for. It's a small device and inexpensive. https://www.amazon.com/Expander-Converter-Shifter-Japanese-108Mhz/dp/B06Y2Z93MW Click to expand... Thanks! I had know idea this existed!
