NISSAN MICRA SRi - APEXI AFC 1
ive seen these but didnt know what to make of them.
did you get a noticable difference when using the apexi safc?
i doubt ill ever have the money to convert to turbo so the greddy e-manage is a bit too much kit for the mods ill be running.
i think i need some kind of fuel/air controler to get that extra bit ooomph!! out the car :p
Just so you know any piggy back device on the K11 ecu behaves rather oddly due to the RPM enrichement curve of the stock ecu.
What this means is you will never get a good fuel reading at all load points. It can mean 1st gear acceleration is massivly rich if 5th gear is set right, or the opposite is true if done the other way. Neither are particulary that nice, or will give the kind of results I would want people to have, so I don't recommend safc or even e-manage for the K11's any more.
is there any kind of air/fuel management that you would recommend?
or do they all have this undesirable effect?
thanks
