CMF_nsm
» CMF MemberHey All....
As a Micra enthusiast,i thought i might try and help everybody with some common parts for these Nissan Micras.All parts are Brand New and come with 12 Months Manufactures Warranty.
KYB Front Shocks....................$105.00 ea
KYB Rear Shocks.....................$58.00 ea
Camber Bolt Kits....................$88.00
Water Pumps.........................$67.00
Top Radiator Hose...................$14.00
Bottom Radiator Hose................$18.00
Coolant Temperature Sensor..........$30.00
Oxygen Sensor.......................$98.00
Oil Pressure Switch.................$12.00
Spark Plug Lead Set.................$84.00
Distributor Cap.....................$38.00
Rotor Button........................$16.00
Ignition Coil.......................$59.00
Series One 52mm Fuel Pump...........$144.00
Series Two 38mm Fuel pump...........$159.00
VRS Gasket Set......................$148.00
Full Gasket Set.....................$186.00
CV Joints...........................$68.00 ea
Front Engine Mount..................$43.00
Rear Engine Mount...................$69.00
Right Hand Engine Mount.............$87.00
Left Hand Engine Mount(Auto)........$69.00
Left Hand Engine Mount(Manual)......$89.00
RPM Clutch Kit......................$144.00
RPM Ceramic Clutch Kit..............$355.00
Exedy Std Clutch Kit................$109.00
Exedy Organic Clutch Kit............$228.00
All these prices include GST...Postage to anywhere in Australia is $15.00...Local pick up is available (Hurstville)in Sydney...if there is any other items that you are after for the Micras, please dont hesitate to contact me...I am currently trying to source Wheel Bearings and front Steering Components and will let you all know when they will be available...
Regards..
Nick... 0411 600005...
Regards..
