Nissan Micra k12 radio code
👉 K12 Radio Codes
"This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code."
Thanks for your reply,
I checked there and also took the radio out but there was nothing.
I took the radio out today but couldn't find the sticker that others have posted on hear.
Did find this etched in the metal
Sn: Bp86351233920
I hope this is helpful
Kind regards Peter
Hi all I've done the exact same thing
K121383039
DEDA49568498
18015066
Found this in the glovebox
Sn: Bp86351233920
Kind regards Peter
Sn: Bp86351233920
Kind regards Peter
You've left a digit out of the serial number, there should be 12 numbers after 'BP', not 11. Edit:- Just looked at the pictures and as there is no 'BP' engraved before the 11 digit serial number, it would appear that it is not a Blau Punkt radio, so cannot help.
👉 K12 Radio Codes
Hi I am looking for a radio code as well could you please help? 28 185 AX613 HP 3123 was the number I found on the back of the unit but I didn't see a BP number
Hi.
Need a code for this radio after battery disconnect on a new k12 2006.
Blaupunkt BP538469506350
There was a label taped on behind too;
28185 BC41A
ZH-D912
Photos attached.
Any help greatly appreciated.
Thank you.
Hi.
28185 BC41A
ZH-D912
Photos attached.
Thank you.
Hi try 9732 or 1732...
hi could someone please generate a code for this
radio
bp334936364988.
had to replace the battery after getting a sill repaired to keep this little 2004 (65k miles) tekna on the road..
could not find the code after the work was finished.
4287 was supplied by the main dealer but won't work..
thanks in advance
colm
radio
bp334936364988.
thanks in advance
colm
4287 is the correct code for your radio so suggest you are not entering it correctly... https://www.onlineradiocodes.co.uk/pages/how-to-enter-nissan-radio-code
hi just tried and no luck... followed the listed instructions.. didn't work. wait 1 hr...any other ideas or codes please... thanks...colm
The 'wait one hour' message needs the ignition on and the radio on for it to go away, till that message has gone, and you are back to the 'Code' prompt you will not be able to input a code and unlock the radio...
👉 K12 Radio Codes
Good afternoon..
My Mother I law has a 2007 Micra sprite, she has just had work done whete they disconnected the battery.
On collecting the car the radio now needs a code and my mother in law has lost paperwork.
It has an original blaupunkt Radio and all I have is VIN
SJNFBAKICU2260573
Could anyone help me with the code please.
Tyvmia.
Good afternoon..
SJNFBAKICU2260573
Tyvmia.
G'day from the Land of the Finns!
You need remove radio from dash and get serial number of the radio from label at back.
VIN doesn't help to get serial number.
You can find radio removal video from YouTube
I manage to get this code by removing the radio..
BP5384 7 121 5101
PN 7 645 384 318
Would anybody know the code please.
Thanks so much.
