K12 Radio Codes
Hello can you help me too? I have nissan micra 2007 bp5384 7 1219355
Hello,
Code is . . 9074
Hi
Any Help would be greatly appreciated
I had to get a new battery for a Nissan Micra. Once I replaced the battery the radio requires a code.
Can you please provide me with the radio code
Serial#DW3CN27672
Part#:281853HN4B
Prod Date#'; 13 12 17
Hi
Serial#DW3CN27672
Part#:281853HN4B
K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
Sorry, I thought this was for any Micra radio codes
The battery recently went flat on my 2006 Nissan Micra. I have removed the radio to get the serial number:
BP334958116163
It would be amazing if someone could send me the code for this!
Many thanks
Hi guys can please help me with radio code HP83N00798235FA0B
Hello members,
My Nissan Micra 2003 battery went flat, after replacing the battery, the stereo is asking for a code.
Please help me,
Serial- BP234632513620
Batch- 7642346318
Thanks in advance.
Hello, I had to change the battery in my car and now it asks me for the code. Nissan Micra K12 2010 Australia. I appreciate if you can help me.
Hello helpful members. Please can you help with a radio code
Serial number is BP 538463844382
Thanks in advance
Bonjour à tous, après remplacement de la batterie, ma micra du 22/01/2004, la radio m'a réclamé un code que je n'est pas trouvé dans les papiers de la voiture.
Voici les références au dos du poste :
BP 234 732 054 150
7 642 347 318
Je vous remercie par avance de votre aide.
Eric
My code seems to be pp3001rb0003885. That does not start with BP... It's a clarion pp3001m.
Am I in the wrong section, or can you help me with a code?
BP 234 732 054 150
7 642 347 318
Eric
Hello,
The code is the . . 5575
Is someone available to help with getting my radio code please? I originally tried to change to aftermarket radio but was causing power issues in the car for some reason so have changed back, now needs code?
BP234631995182
7642346318
Fil de discussion sur le code radio K12
Ceci est le fil officiel des codes radio K12.
Veuillez fournir votre numéro de série (commençant par BP ) en réponse à ce fil de discussion.
Veuillez garder à l'esprit que les personnes généreuses qui fournissent ces codes le font pendant leur temps libre, alors soyez patient lorsque vous demandez un code.
Bonjour
Suite à un remplacement de batterie sur ma Micra K12 1.2 je n'ai plus le code radio.
BP536158182389
7 645 361 618
Merci d'avance 🙏
