Any help greatly Appreciated
About 70,000 on the clock - nothing but trouble since i've owned it / least reliable car I've ever had - soon as I've got spare cash 💸 running back as fast as I can to toyota - only ever buying toyota till I die from now on -
Need this vechicle running really bad ATM very short on time
Upon start up car immediately dies unless you really hit hard the gas every time - then it runs fine but occasionally dies in busy traffic 😅
Changed the oil religiously about every 10k
AA man said he believed the issue was bad plugs or coils- which I suspected was bull - but went ahead and immediately fitted brand new coils and plugs - car running slightly nicer but exactly same problem - I used to rate the AA but like everything else in the UK ATM their service has gone from brilliant to broken - just like my nissan micra -
I'm not a mechanic and only know basics of cars - I suspected fuel pump so fitted a new one - exactly same problem persisting -
Took throttle body off cleaned the hell out of it with appropriate cleaner - same problem persisting -
New air intake filter-
I have a reasonably good odb reader about £900 - threw up a few fault codes relating to cam shaft position sensor so immediately ordered new nissan parts and fitted both cam and crank position sensors- exactly the same problem persisting -
Just ordered brand new throttle body and battery fitting those in a few days - see if it makes any difference - battery has good voltage but may be original or one after original bought the car at low miles so can't be sure - battery tests OK but can't hurt to change it
Dont know enough about how cars work fully so it's a bit like throwing darts at a dart board in the dark and hoping for bulls eye 😬
On top on this had to change all parts for the boot - and silicone around the boot lift switch as everything failed and was letting water in - not impressed
Special cleaning spray as the front lights go really really cloudy without attending to them every now and again - not impressed
Both speakers have failed and I have had to change them - not at all impressed
The wiper arms are f-ing horrendous and make like a really really loud slapping noise - like the worst in any car I've ever had - the most horrible sound you can imagine - don't want to fork out for more new parts on this junk ATM - bet the motor and arms cost bucket loads
How any body in thier right mind could rate this f-ing badly made junk is just beyond me - I've has more reliable fiat's that this k12 f-ing junk
Bought my mum a k13 a couple years ago and the clutch failed at 40,000 got a great company to do it on my drive for cheaper than garages - but a clutch failing at 40,000 - think maybe all micra are badly made total junk
People say the k11 was really good - probably should have bought that but they so old could not find low mileage examples-
All of the motors for the wind screen wash have failed going to have to change them -
Anyway back to the point- if changing the throttle body for new one does not work - anybody got any ideas ????
Going to change pcv valve as somebody told me that could be an issue as well /
Might change main 02 sensor as well 🤔 can't Hurt - seems easy to do -
On the plus side its made me decent cash delivering pizza and deliveroo monies and had pretty hard life -
And think the k12 has electric power steering - which is beautiful beautiful for delivery work - like so good - and had zero issues with the brakes so far 😀
Also l lite engine so beautifully good on fuel consumption
Any body got any ideas at all so I can get a bit more life out of it - before I run 🏃♀️ 😅 🙂 back to TOYOTA a proper car company that make proper cars -
THANKS
Any ideas so I could at least get 100,000 miles out of the k12 piece of f-ing junk while I'm stacking cash for my toyota auris
Got about another £500 to throw at it before I give up
Any and all help greatly appreciated - cheers don't want to scrap it at 70,000 miles 👍 but looking very possible / probable if I can't find out whats up with it - don't have any disposable income for garage ATM before any body says take it to a mechanic -
THANKS
