Nissan Micra K11 1.3
Hy there i own a Nissan Micra k11 1.3 year 1999 , and i have a problem with the front windshield pump i think.. !?? When i`m washing the back window the pump its working (i can Hear it also) but when i want to was the windscreen the pump doesn`t work.. the blades are moving as normally but the pump its not working.. !!
What can i do? Thanks!!
^says the washer pumps not pumping, not blocked.
check the windscreen washing switch on the steering stork is switching fine, then check wiring circuit from battery to stork to pump.
I found the problem !! :)) The Little car has 2 pumps: one for the front wipers and second for the back :)).. and one of them (front one) was broken .. :(
Thank you all!!
