MICRA K11 CG10DE
can someone help to find right replacement fuel pump of my nissan march(micra) k11, some one knows the rating of how much does the fuel pump flow letre per hour(lph)... i cannot find orig nissan micra k11 fuel pump, since this car isold enough and hard to their parts. i bought exact design fuel pump from nissan sentra 1995 the pump has only 1 backflow of its pump compare to the stock fuel pump whis has 2 hole or back flow. please refer to the attached image. the problem of my nissan micra(march) is, i already put a universal pump, the problem is i can feel the engine is running in rich fuel and cant burn all the fuel, because i think the fuel pump is universal and not design for nissan micra and with high flow rate.so if its run in high rpm the engine is okay, but when i met in traffic, the engine stop.
Write your reply...
