Hello there, I found this older post on replacing a Micra aerial;
http://www.micra.org.uk/threads/replacing-the-aerial-on-the-later-k11s.45562/
But for some reason I cannot reply to it.
Basically my Micra has a broken aerial and I want to replace it. Problem in it looks just like the pics on the above post but the actual screw bit seems to have been snapped off? Ideally I would just by a replacement screw in 'bee-sting' but I do not have anything to screw it into.
I assume I would have to remove the entire bit and replace it. How do I go about doing that? Can anyone link me to a replacement part? (including fitting mechanism)
I will try and post a picture of what it currently looks like for you this evening.
p.s. If this can be moved to the old post or I can be given the ability to post on there it would be much apreciated.
Chris
Chris
