Question: new to K 11's
Hi everyone,
i've been racing k10's on autograss witha while but i'm hopin to build a k 11 this year,
i'll just be class one i'll be in,as in striped out,roll cage and seat and harness and another few safety things,
i've a few questions before i start building,
where is the ecu located and if i rivit it to the bulk head with all the origial connections will the run fine?
to change it to a button start will i have to by pass an immobilser?
does anyone have spec for a roll cage for a k 11?
I'll prob be wrecking your heads for more info as i go and i'll start posting up pictures!
any help would be great,
thanks in advance
the ecu is near your left foot diarmuidma, and you would be best to fit the early (pre-nats) engine loom and ecu
thanks frank :)
from what year was nats common in k11's?
94 i think mate, then nats 2 till around 98ish ? then another type i believe, its really best avoided, and the engine loom and ecu is pretty much 1 unit, but the non-nats ecu plug is a different pinout tho
