J Jeroen330 Jan 11, 2011 #1 Hello all, I need some pictures of the space i have to cut in my chassis dureng a GA16 swap. Does someone have some? Please post here! I need it to get my K11 GA16 registered soon! Kind regards, Jeroen330
O oikealle Jan 12, 2011 #2 hi Jeroen, just out of interest matey what driveshafts and hubs u using, might build one for a work commuter!
OP OP J Jeroen330 Jan 13, 2011 #3 GA16DE USDM (115HP), standard engine mounts, CG13DE gearbox, Nismo CG13DE driveshafts.. As i fit the GA16 on the same place as my CG13, i can use the CG13 gearbox and driveshafts. Why?
O oikealle Jan 14, 2011 #4 Jeroen330 said: GA16DE USDM (115HP), standard engine mounts, CG13DE gearbox, Nismo CG13DE driveshafts.. As i fit the GA16 on the same place as my CG13, i can use the CG13 gearbox and driveshafts. Why? Click to expand... I was thinking of building one pal. So is it more or less a straight swap? Thanks for your help
solarice Ex. Club Member Jan 14, 2011 #5 Personally i wouldnt cut it, but maybe thats just me. From when ive seen them they've been pretty much just a triangular cut. Have you looked into an electric pump? i understand you have no clearance issues if you fit one.
frank Club Member Jan 14, 2011 #6 i would portopower the chassis rail over a bit personally :grinning: there,s an inch or two of clearance to the suspension leg (or more with coilies)
