Need conformation on this error code
Hi guys, I need conformation on this error code.
Some off my friends give me for my K10 MA09ERT ECU.
Because the error code that he give to me is common Nissan Error Code.
Can this be apply to my K10 ECU diagnos.
Many thanks in advance.
Nissan Error Codes:
The error codes are sort of like the honda ones.
It has 2 LED's inside the ECU you can see though a little hole.
The RED LED = 10
Then GREEN LED = 1
So if the RED LED blinked 3 times and the GREEN LED blinked twice you would have error 32.
The error codes are as follows:
PHP Code:
11 Crank angle Sensor
12 Air Flow Meter
13 Water temp Sensor
14 Speed Sensor
21 Ignition signal missing in coil
22 Fuel pump
23 Throtle valve (idle)
24 Neutral / Park (not a fault)
31 Heater/ Air con (not a fault)
32 Starter
44 Other electrical fault.
