NCVT Problem.
Hi, i have a 1998 1.3 Micra with an NCVT gearbox.
It's only just done 40,000 Miles and has an intermittent fault.
The NCVT light comes on and it will not go into drive, the gear selector moves but no drive.
Any suggestions ?
Just found this !
"You may want to try this if you haven't already.
The following should put the automatic (N-CVT) gearbox into its self diagnostic test, helping you narrow down any problems youre experiencing.
Self Diagnostic Method:
1. Keeping the ignition off and all pedals released move the selector / gear lever to the "D" position.
2. Turn ignition on - but dont start the vehicle.
3. Depress and hold brake pedal, then fully depress and hold the accelerator pedal.
4. Then move the selector / gear lever in the following order: Ds - D - N - R - P
5. Release the accelerator pedal, then the brake.
6. Start the car...(gear lever still in "P")
7. The N-CVT dashboard warning light will start to blink, count them and compare with the fault code list below)
8. Switch off ignition to stop self diagnostic procedure.
The fault code output blinks are made up as follows:
No fault found: There is a 2 second pause, followed by the light remaining on for 2 seconds and then 7 short on/off second blinks.
If a fault is detected one of these 7 short blinks will remain on longer than the others.
Fault Code 1 - The first blink is on longer than the others - Accelerator or accelerator position switch circuit is short circuited or diconnected.
Fault Code 2 - The second blink is on longer than the others - Inhibit switch circuit is short circuited or diconnected.
Fault Code 3 - The third blink is on longer than the others - Vehicle speed sensor circuit is short circuited or diconnected.
Fault Code 4 - The fourth blink is on longer than the others - electro-magnetic clutch coil circuit is short circuited or diconnected.
Fault Code 5 - The fifth blink is on longer than the others - Line pressure solenoid circuit is short circuited or diconnected.
Fault Code 6 - The sixth blink is on longer than the others - Torque signal circuit is short circuited or diconnected.
Fault Code 7 - The seventh blink is on longer than the others - ABS signal or idle up relay circuit is short circuited or diconnected.
Fault Code No Number - Lamp blinks at 4Hz repeatedly - Battery supply fault or memory back-up fault.
Fault Code No Number - Lamp does not blink - Check all components.
