Just gave the micra a good drive from home(murwillumbah) to watch the footy (titan v Raiders @carrara,gold coast) and didn't have any trouble with leaning out, must've been residue from install or something. I do highly recommend this upgrade to any one who wants more go, the only change i had to do was transfer the throttle cable hanger, that's it, EASY. Places where the micra usually struggled (tight hilly bits) it just accelarated thru them, very impressed and I was lugging a 98kg passenger. I also did a 0-100kph test on the way home, (i usually use the same bit of road, chugg along at idle and then go, it gives slower numbers but takes away the starting irregulaties) normally in N/A mode I get 11.3sec now it is 10.7 on full fuel! just by swapping the tb. to answer maat, I have a few options, I have got some primera injectors (108cc/min from polar in the short term (putting them in next weekend) and in the longer term, I have a modded SR20DE (320cc/min) fuel rail that just needs to be welded together.
