The donor car arrived.
It is a nice thing: SuperS, 4 disc brakes, climate, electric windows, central lock, and of course a CG13DE. I'm going to install all of these features to my K10 ... somehow
The first project is the brakes.
The K11 had a solid disk in front (D'OH, my K10 has vented), and caliper cant support the 19mm thick discs, so i will put them to the trash. I will change only the hubs, and install Mitsubishi calipers and discs (because they have in stock). 238mm vented, same parameters as the K11 brakes had to be.
Question:
My K10 (MA12 engined) driveshaft outer joint's parameters:
Teeth number outside 23
Teeth number inside: 19
K11 SuperS (CG13) driveshaft outer joint's parameters:
Teeth number outside: 23
Teeth number inside: 22
I cannot interchange them, but will my driveshaft fit for the K11 hub?
The rear discs seems to be easily fit ...
