Greetings from Hungary !
I wanted to buy a cheap modest car for go to work, and I found this The good points was it started immediatley, mechanically seemd OK, but the chassis was as rusty as any japanese car in his age. As this is a 3 door car, I need to replace only 3 doors (plus a fuel refill door)
The engine is good despite I drained tar from the oil pan. Somebody missed few oil changes before. The belts ok, but I need to replace them too. The exhaust had a big hole, needed to weld, but now it is OK.
The bad points aside from the chassis is the electronics.
Here is the few things what don't work:
- horn
- rear wiper + washer
- front washer
- back up lights (oh, anybody have a working switch? )
- rear fog lights
The solved things:
- fuel meter
- stop lamp
- headlamps
- radio
- speedo
I installed BWA Racing 6x13" rims, with 175/60 A539.
Have to do a lot of things with it but now its running The suspension is worn, i'm going to replace the old brushes with polyurethane.
Here is a few pics from the thing:
I have to lower it a little bit
Yes, this is a hole
In my future plans I'm going to install Mitsubishi Sigma front fog lights (just a little modification in the bumper), and cut a Fiat Sceicento leather roof to improve the leaky sunroof. I'm going to make a Tropic version
The fog lights:
Oh, the car was cheap, I bought it only for 260 euro (Ł 221) Maybe it worth it I'm going to refurnish it slowly, and keep in alive
- horn
- front washer
- rear fog lights
The solved things:
- fuel meter
- stop lamp
- headlamps
- radio
- speedo
Yes, this is a hole
The fog lights:
