Red: Need advices from you guys.
Nearside Headlight
-Nearside Registration plate lamp not working.
I need to replace new reg plate lamp so it will be working if i change new bulb.
-Nearside front Headlamp not working.
This headlight plug is mess up so these wires are so wrong. i need to soldering it so these wires are no clues to me. How can i find these wires are right to connect to other wires.
Front Suspension
-Offside outer front suspension arm ball joint dust over excessively damaged so that it no longer prevents the ingress of dirt.
I need to change CV gaiter so is it correct?
Tyres
-Offside front tyres incorrect because different size tyres are fitted on the same axle.
All these tyres should be same sizes.
-Offside front tyre tread depth below requirements of 1.6mm.
I need to get new tyre.
Wash screen
- Front windscreen washer provides insufficient washer liquid.
This is so funny lol. I asked my little brother to do it so he put water in it. Obviously, I will put new wash screen liquid after i sort these errors.
Advisory Items
-Offside front (on outer rim) road wheel slightly damaged.
This wheel was hit by kerb so in soon, i will replace another good wheel.
- Front brake pads are wearing thin.
I will change new brake pads soon.
Thanks for reading guys. I hope you guys will say something.
cheers guys
jk
Nearside Headlight
Front Suspension
Tyres
Wash screen
Advisory Items
cheers guys
jk
