Since getting it on the road I've had to do a number of things to keep her running.
I've had to adjust the choke, as the spring popped off.
I had a static tune to get her running nicely.
Changed the wishbone bushes.
Changed the front brakes.
The clutch was slipping every time I put my foot down so I bit the bullet and spent £300 on getting that done.
Changed a wheel baring (that wasn't fun or easy)
Changed the steering rack.
Most recently she decided to break down on my way home from work, I found out that the previous owner had changed the dizzy cap, condenser and rotor arm but installed it in correctly. So I got all new parts changed the dizzy cap, rotor arm, condenser, points, leads and plugs she now runs perfectly if I do say so myself. But I still need to change the rocker cover gasket as I think it my be the cause of my burning oil issue!!
