My CG13 Screamer Project Wishlist (loads of parts needed)
All,
Ok the plan is to build a 1.3 engine up using aftermarket parts and also my own handywork.
Its going to be a little hit and miss i am sure but this is what i want/need.
A CG13 Engine (only really need the block/head and the inlet manifold and fuel rail. (engine HAS to be in good condition - ideally less than 80k on the clock.
GA16 or SR20 injectors.
Ga16DE Throttle Body
Janspeed (or other) 4-2-1 manifold
Full exhaust system
Fuel pressure regulator (ideally apexi).
Fast Road Camshafts
the plan is to build the engine back up based on the above parts.
I will also be doing the following (i have access to some good tools).
Ported/polished head
Ported (or maybe customised) inlet manifold to help restriction
Lightened and balanced flywheel
I am looking to acheive 100bhp at the flywheel.
This is not a fantasy and i am hoping to obtain the engine and start work on the porting/polishing aspects of the job in the next week or two.
Anything you have let me know.
Kind Regards,
Luke
All,
Full exhaust system
Fast Road Camshafts
Kind Regards,
Luke
have a look at my buy and sell thread ;) i should have some of those bits
hi luke
i bought a 1.3 engine (£50), primera injectors (£15) and primera T/B (£20) from yards in our home town
my twin T/B setup is for sale, and i could sort you a flywheel if you want
Frank,
tell me a little more about your twin setup.....
also when you say you can sort a flywheel i take it you mean a lightened flywheel??
Any contact you have got for sourcing the engine, and injectors would be much appreciated.....
Luke
