Napster
And the Wide Green Bug
As you can tell from the title my micra has a problem :-( the car started fine yesterday morning and got to college fine and parked up. the car had been parked up for about 7hours with it being started or moved. after college i went to it. did the usual, put key in ignition and turned "two clicks" the four lights are displayed on my "instrument panel (battery, air bag light etc)" when the airbag light goes off i then usualy start the car. so the light went off. i turned the key to start the car, but NOTHING HAPPENED except all lights faded on the display. the car didnt even tick over :-( the car was left over night at college and i only live a mile away from so not to bad. i couldnt do anything about it yesterday cause i was working till late and it was rainning so i left it till this morning.
my mate and i got it started with jump leads and so i drove it back home about 30 minutes ago.
i got home fine, parked up and thought ill try the car again:
"however the same is happening. the car isnt starting and all the lights failing"
i have power to headunit and lights etc, but thats expected though isnt it even if i have got a flat battery?
is this a "battery problem" or an "alternator problem" or something else?
thanks
napster
thanks
napster
