squarepants
basiclly started it up this morning, and just kept dying after about 2 seconds, tried agian and died agian. tried agian and it ran until i touched the thrrottle and it died... sounded like the cam chian was beeing really noisey! like there was no oil in the head, on the cam chain or on the cams..
started it up agian, this time pumping the throttle, the egine kept poping (as if the sound was coming from the spark plugs) and it ran but anything under 3000 it would start to judder.... tapping throttle agian, it was just poping agian then ran....
then engine cheak light came one... i popped the bonnet, took out my spark plugs (seem fine, gave them a clean aswell) checked my ht leads (working fine) put it all back together... also topped up the oil...
car still was the same, anything under 3 it started to juddered all though felt better than the first few times i started it...
left it 20minutes, put some water in and strated it agian, anything under 3000for about a minute after starting it would judder....then it was running fine i still can feel the juddering at low revs slightly tho, not as bad as before but its there...
its not fuel as its got about £8-9's worth in.
its not the leads
its not the oil
so the problem is possiable plugs. (i have some new ones just aint fitted them yet)
water (topped up today...)
or antifreeze?
iam scrathing my head over this...what the frig is it!?
its not the leads
its not the oil
or antifreeze?
